any good? (ka24de mainfold t04e)
turbo2nr
Car: 97 240sx (kouki)
well basically a ssautochrome, t3/t4 mainfold. is it any good? i have head mixed opinion about this company some good some bad.
http://cgi.ebay.com/ebaymotors...wItem
for that price its a steal. but is it any good? or will it fall apart?
thanks
1
Craving4Boost
Car: 91 240sx fastback
not only did you not search but you only have 1 post....
fabio420
Car: 1995 nissan 240sx se
To answer your topic, I have the info. I bought one a while back. Now the first thing that gave me problem was fitting. You'll notice it says "altima" which means, fitting issues. In my s14, I couldn't make enough room for my tiny t3 to clear the brake cylinder when on the manifold. So that's the first issue. Secondly, the welds bled like crazy. When the head gasket blew, and oil was being pushed through the exhaust, you could see clearly oil oozing out the welds. So basically, don't buy it, it's a piece of CR*#! The manifolds mentioned here are great, but I can see that they are a bit pricey, but that's most manufacturers. I did find a good forged manifold that has never given me issues, and it was $275. Down in Miami. But to recap your question, don't buy it. If you do, be prepared for major headaches. Save up more money and get a good one. otherwise you'll just waste more money, like me.
hysteria
Car: s13 kat, sv650s, and other projects
i've heard good things about ss autochrome. they are supposed to make bullet proof manifolds, and turbo's that will live longer than you. you should buy everything you can find from them, even if you don't need it. that stuff is like gold... you can never have too much.
if i had the money i would buy ssac all the time but they are a little pricey for me.
you should just get an sr20det... man i hear them things have like 500 hp stock. and then you can get a blow off valve. i think they add like 20 hp, depending on what size it is. get a wastegate too.
seriously though, there is a search button.
turbo2nr
yea i did the search the ssa mainfold are crap. i was just trying to put together a cheap turbo kit for my s14, so far i have a to4b, hks ssqv, boost, a/f gauge, and i know a place that will make me a 3" downpipe, i'm buying a fmic soon, so all i need is the i/c pipes and mainflod and oil lines and ill be turbo again.. only plan to boost 5-6 psi on vortec fmu and a walbro 255.. ill probably get a revhard, its good price and the cheapest..
thanks for the help 1
lrb_2000
Car: '91 Nissan KA-T hatch
good call on the revhard!
HolyShiznit
Car: Working on my car
And while your at it, sell your turbo for something smaller, at only 5-6 psi you are horribly out of the effieciency range of that big T04 and it will spool slow.
fabio420
for 5-6 lbs, you don't need an FMU. btw, but if you want on, I have one.
Florida240sx
Is it jut a worthless A/F gauge or is it hooked up to a wideband?
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
That ebay auction is too funny...
1st off:If u look at all the pics of the manifold from different angle's, ull notice that the last manifiold picture is not the same as the other one's...
2nd: The turbine shown is a 5 bolt output. The downpipe is a 4 bolt flange. Although the turbo and downpipe are not part of the auction, its just funny that they put that stuff in there..!!
This is way too funny..!!!
fabio420
Florida240sx wrote:Is it jut a worthless A/F gauge or is it hooked up to a wideband?
ouch! ha-ha!
turbo2nr
im gona stick with the to4b becasue im planing later to boost 15psi, but thats after some 555cc injectors and a jwt ecu, and a msd btm,
question how much do i retard the timeing when only boostin 6psi?
and yes the a/f gauge is useless, it will just fill a space in a 2 pod gauge pillar.
Craving4Boost
turbo2nr wrote:yea i did the search the ssa mainfold are crap. i was just trying to put together a cheap turbo kit for my s14, so far i have a to4b, hks ssqv, boost, a/f gauge, and i know a place that will make me a 3" downpipe, i'm buying a fmic soon, so all i need is the i/c pipes and mainflod and oil lines and ill be turbo again.. only plan to boost 5-6 psi on vortec fmu and a walbro 255.. ill probably get a revhard, its good price and the cheapest..
now were talking...alright...yeah the revhard is a good manifold..its what im running....ive seen people selling them used for as low as 275....you dont want it too old but just prep it...
if your only running the fmu for a short period of time like a few months you should be fine...dont let people convince you too run without an fmu...im assuming your knew to the turbo scene so lets keep it safe as possible.
since you have a msd btm, smart move bwt, just set it to .5 degrees retard per psi and your good...
looks like your off to a good start...just keep in mind never buy SSA...its ironic....to save money..you must spend MORE money to do it right the FIRST time..instead of going cheap and blowing it
turbo2nr
yea i taught so, im not a newbie to turbos, im a newbie to this forum, im on automotiveforums/ka-t.org and zilvia.net also probe talk .com
i had a turbo 91 probe gt thats where i learned about turbo and what works well and the balace you need to matain with a turbo car, to much of one isnt good wether is air, spark or fuel, you need to balance it.
i know how important fmu is so thats why ill deffinatly get a walbro 255 and a vortec fmu for now..
thanks for all the help.1
