s13_240_rb20 »
https://forums.nicoclub.com/s13-240-rb20-u87143.html
Wed Nov 18, 2009 2:02 pm
OK....I am seriously losing my mind.
My engine is the RB20DET, but I am trying to figure out the Hardbody wiring to make my alternator work.
There are two screw-on connections: I have 12v and I have the GROUND. Then there is the plug with a big white wire and a small white/red wire (charge light on dash?? dropping resistor???) They are different colors on the hardbody alt, iirc, so please just call them the big wire and the small charge light wire.
I have the big white wire run to the battery also. With the small white/red wire detached, it doesn't charge. Detached, the small white/red measures .006v. When I attach the white/red to the battery, I instantly see the volt meter jump to 16v or so (CHARGING!!! I think??). But then the engine stalls in a few seconds.
It does that every time!!!!!
I have been searching all day for the correct wire in the engine bay (from the truck's dashboard charge light system, which is a yellow/black wire behind the dash), and couldn't ever seem to make it work with the yellow/black wires I tried under the hood. every time it senses voltage given to the white/red wire, the engine stalls. Can anyone tell me what to do or if I can hotwire it some how and make it charge without stalling?? Or why it is stalling????
Thanks for ANY input!!
--TJ
