KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Mon Jul 24, 2006 3:23 pm
Honestly, to make 300hp on that setup, you'll have to run some kinda high boost pressures (probably around 16-18psi?). Also, you'll want the .86 (or maybe it's .82...can't remember) A/R turbine housing, otherwise the exhaust will choke in the upper rpm range. It will most likely still run out of steam in the upper rpm range, as far as torque is concerned.
The most suitable unit to efficiently make 300whp on the KA is the T3/T04E .50 trim (not saying that because I have one, but because compressor maps don't lie). Another good one is the GT32 from AMS, which will be about the same $$$ as a new T3/T04E, but comes with ball bearings. And the GT35R is good, but it's about $1200, and would be a tad bit overkill.
While these won't get you a bottom mount setup, you will have a safer setup, as it shouldn't require more than about 12psi to hit your desired power. Also, the torque curve will be much better. You could opt for the .48 A/R if you want quick boost response, or you could go with a .63 A/R and have full boost around 3700rpm, sustaining it all the way to 8,000rpm, if you so choose to wind it out that far.
Just something to consider.
