raremotive »
https://forums.nicoclub.com/raremotive-u77973.html
Mon Sep 15, 2008 10:58 am
There's nothing to worry about a break in period, if anything was going to break... it would break regardless if you rode it hard or lightly.
Only thing in the engine that needs to be broken in is the ring and cylinders to get optimum seal.
Which driving slow or at idle will not help the process of sealing the piston rings or cylinder walls..
To break in, drive it like you are going to drive it. Up shift and down shifting are equal in importance to providing the loads to the rings against the cylinders.
Everything else in the system is protected by oil, which is a non-compressible fluid...so regardless how hard you run your motor.. as long it gets it's oil, it will be fine. Which is why starting up a engine while cold is most harmful. Because the tension in the mechanical system causes components within the system to shift resulting touching metal to metal. Which is also the advantage of a dry sump/external oil pump, which primes the oil before cranking.
