They usually don't put it on due to the variation from many things. See my other post.awdjdmtalon wrote:I believe that it is watts per hour usage on the pump.
Yessum. V*A gives you the maximum watts, or power, that could be used at any point. The pump isn't the reason for your high energy bill. Its something else.awdjdmtalon wrote:I believe that it is watts per hour usage on the pump.
The electric company can't calculate the number of electons that they give you because it's a/c lol.turbobrian wrote:So if this pump draws 1380 watts. And it turns on 10 times a day. Would that be 13,800 watts it uses a day so (13,800x30) = 414,000 watts a month? move the decimal 3 places and get 41.4 kilo watts? 14.4 kw x $0.16 = $6.62
I am not an electrician either but for a total bill of $73 my guesstimate is that sump pump electrical useage is under $10 and perhaps under $5?turbobrian wrote:I am trying to figure out how much money my sump/water pump is costing me. I rent a house and this pump turns on 15 times a day for 5-8 seconds. We rent the basement level and because we are below the water level the pump gets rid of all the water from the toilets, sinks, washer, dish washer etc. I think it is adding at least $30 to my bill every month. The landlord does not think so. To compare a different house which I know is hard to do but...a house I own in another state that is a 2 family. I pay the electricity for both units and the bill was $73 (471 kwh) last month. The place I rent which is only 1 unit of 2 was $175 (1108 kwh). This is why I think something is wrong here.
The pump is 115v at 12 amps max. it is a 4/10 hp which I would guess is 1/2 hp
if I use 115v x 12= 1380 watts
watts x time = energy use
so if this thing draws 1380 watts is this per second? or do you fiurge this out per minute or hour?
I am a little confused.
Modified by turbobrian at 6:16 PM 6/27/2008
