The main difference is the harness on the CAS, but otherwise it's good to go. You can't use the 94 CAS on the 90-93, so you'll have to splice in a new connector to your engine harness, but I *know* you have the capability to do that...
You'll want to use the newer style injectors, and of course you'll need to switch the chain guides.
The 90-93 have the two Siamese ports on the intake runners/head versus the oval ports on the 94, which I don't really think makes a whole lot of difference in the big picture.
The 90-93 DO gain the sodium filled exhaust valves, which is very much a performance gain especially with boost!
