Rucca »
https://forums.nicoclub.com/rucca-u71259.html
Mon Apr 21, 2008 6:26 am
Well, the brake booster helps you apply extra force to the brakes, so it really isn't an ABS related part. On rockauto.com I cannot find anything but a Brake Booster for a Z32, no ABS or non-ABS part so that would lead me to believe they are the same.
A faulty brake booster would leave you with a hard pedal that felt ineffective. Like stepping on a rock, and you describe the pedal as spongy so lets rule brake booster out.
Master cylinder problems would leave you with a spongy ineffective pedal, however, you have replaced the MC so I assume that is OK. Although, I would keep the MC in mind. New parts can be bad, and if it is a used unit you never know.
Since you say that bleeding the brakes professionally left you with firm brakes for 10 mins, I'd suspect a problem with the calipers possibly having a small leak and letting in air but not letting out fluid or not much fluid at least.
In short, I'd check all lines for leaks. If you don't find any put your old 240 calipers back on and see if the problem goes away. If it doesn't, replace MC, if it does, replace Z32 calipers.
