duece.four.oh.sxhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113any body running a MBC on a RB25 need install help?Fri Oct 12, 2007 8:23 am
Postby
duece.four.oh.sx »
https://forums.nicoclub.com/duece-four-oh-sx-u45114.htmlFri Oct 12, 2007 8:23 am
like the topics say's does any one have a picture of it istalled or a diaphragm .i tired installing a hallman ball and srping type and after it reached 10 psi now my engine sounds really wierd (i took it off now i have no boost)i just want to see other install's so i could get an idea if i did it the right way ......thanks Danny
Postby
Shocker »
https://forums.nicoclub.com/shocker-u18595.htmlFri Oct 12, 2007 8:39 am
I run the same boost controller, the top part of the MBC, like the longer peice, where you adjust the boost, that line needs to go to a vac source, the bottom nipple, thats perpendicular with the top part goes to your wastegate nipple.
Postby
lilskyline240 »
https://forums.nicoclub.com/lilskyline240-u33468.htmlSat Oct 13, 2007 7:47 am
actually the bottom nipple goes to the vac source. the side nipple goes to the wastegate.
Boost enters through the bottom and is held there by a ballbearing and a spring insde the boost controller until the specified boost is reached. Then the boost compresses the spring and goes by the ball bearing out the other nipple into the wategate which opens now and regulates the boost
