boker240 »
https://forums.nicoclub.com/boker240-u85310.html
Thu Apr 24, 2008 7:18 pm
do the 5 speed swap or u will regret it!! take it from experience, i did it , the ka auto will not and i meen will not shift on anything over 5-7 psi of boost. u will have to let out and manually shift it from low to 2nd and 2nd to drive.. it just cannot handle the shft pressure under high boost like 10-15 psi,, itll just hover up around rev. limiter and try to shift but willnot until u let off to like 1/2 throttle. this was with a transmission cooler and synthetic fluid!!!! good luck.
