L.A.COUPE wrote:You Wind thanks for the reply,I was curious about the offset, i belive they now come in a 35 offset. That should work with the coupe then right?.. I thought id ask here before making a definate deal with the shop, since they might say it will fit just to close a deal. thanks again!
Modified by L.A.COUPE at 1:02 PM 4/27/2008
Well, personally i'm conservative onthe Offset, owrse case you could always get spacers if +45 isn't your taste (Which is the OEM offset).
There are a few guys on the forum that have +35 and haven't had any probelms so far, even with lowering. You might want to use the following offset calculator to determine the width of wheel you need to go with to ensure clearence. Get out your ruler to measure the changes.
http://www.1010tires.com/WheelOffsetCalculator.asp
or, google for other calculators.
-- Wind
