Any 300zx mechanics in Minnesota?
red300zxna
Car: 1990 Nissan 300zx NA 2+2
Hello, I am relatively new to the car community and I have an oil leak between the transmission and the oil pan in my 2+2 NA. I think the rear main seal is leaking. Not too long ago I took my Z to a cheap mechanic to replace my clutch and its been having problems ever since that. I live in the Twin Cities area. Please let me know thanks!
RubyRed300ZX
Car: 1993 300zx Convertible
There really aren't any 300ZX shops in Minnesota. A leaking rear main seal isn't that difficult or specific to the 300ZX. If you're looking for a decent reputable shop, try Further Performance in Minneapolis. Ask for Frank.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Also, realize that although it can be the rear main seal leaking it also is equally possible it's your valve cover gaskets leaking/failed, as the oil drains down the block and presents at the oil pan/trans consistently...have them checked out to avoid a repeat visit.
As RubyRed suggests, for a rear seal you should be able to have a reputable regular auto shop do it without problems, it's not Z32 specific in any way- just labor. The valve cover gaskets though...if that's your issue be SURE they've been in there more than a few times as it is more Z32 specific.
