any 1 know how 2 take out the lining on the inside of our trunk? help
II Knucklez II
Car: Altima Coupe 3.5 6MT
some how i found out today some one dented the top of my trunk, its small so i thought i could hit it out from the inside. but i dont want to mess up any thing so thought i should ask first.
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
don't tear apart your truck. get something/anything with a decent size suction cup on it and pull it from the outside/top of your trunk. pulling it slowly out will do less damage than hitting it from the inside and you'll have much more control as to what happens when it does pop out.
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
part of my rear fender got kinda pushed in a bit too, it curved inward where the other side curved out ........ weird, no scratches, maybe the weather was just too cold?
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
II Knucklez II wrote:some how i found out today some one dented the top of my trunk, its small so i thought i could hit it out from the inside. but i dont want to mess up any thing so thought i should ask first.
Y
You should be able to figure it out just from looking at it - most likely secured with puch pins or something similiar.
Otherwise you should look under the table of contents here and find the FSM.
07WinterFrost 3.5 SE
Car: 2007 Nissan Altima 3.5 SE
I've done this to install my Clear Brake light on my OEM spoiler. It's all push button clips. You have to undo them before prying them out. They're 2 pieces to each one. The only difficulty part was getting the cloth part off the safety handle and then reattaching it back in place.
