Post by 91nissantwo40sx » https://forums.nicoclub.com/91nissantwo40sx-u70730.html Wed Aug 27, 2008 5:42 pm
Post by 91nissantwo40sx » https://forums.nicoclub.com/91nissantwo40sx-u70730.html Wed Aug 27, 2008 5:59 pm
no i didnt need to bleed bacause i only had to change my pads. this is only on the front left side of the vehicle. and yes the car does have ABS. Before this it worked fine and everytime the car would start skidding i can feel the ABS working. it only started giving me the light after i changed my pads. im going to check the control unit and have a closer look to see whats going on.Hijacker wrote:Did you bleed the brakes at all? If so, check your reservoir and make sure that you have plenty of fluid in it. Heck, check it anyways.
Does the car have ABS?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
