Antifreeze seeping from lower timing cover
freeonboard
1992 240sx: silicone seal leaking I'm leaking coolant where the front timing cover mates the engine block How quickly will this get worse because I'm worried about getting stranded somewhere? Is there anything I can use to stop a leak if I get in trouble ie cotton or some other material to fill crack. Will this just leak slowly for years with no consequences like oil? Thanks.
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
It will be ok for a little while, just make sure it is not leaking in too. You can reseal the front of the block in a day. If you want you could try bars stop leak from the auto stores. It leaks out when the engine is running and solidifies to seal it.
freeonboard
spank044 wrote:It will be ok for a little while, just make sure it is not leaking in too. You can reseal the front of the block in a day. If you want you could try bars stop leak from the auto stores. It leaks out when the engine is running and solidifies to seal it.
Thanks for the answer:)
