Anti-Theft System
Myetball
Anybody have a good system to recommend? Went out to my car this morning to find the drivers door popped and the steering column torn to ****. Radio was making strange noises and display was all goofy.
Anyway, I removed enough parts to completely disable it for now. Will leave it that way until I can get it fixed and get a security system put in.
SmithSR
Car: 240sx
They tried to steal it, but failed... that's the worst. I say, if you want it so bad, take it and never let me see it again.
Check out DEI and it's long line of alarms/anti-theft stuffs.
C-Kwik
Yeah, years ago, I installed an $1100 stereo into my buddies' Acura. Seeing as how we didn't want it stolen and the fact that Honda/Acura's use sleeves to hold the stereo in, I took an extra step to secure the stereo. Basically I used a metal strap and screwed it to the side of the stereo using ons of the iso-din mount holes. Then the strap had another screw in it that I used to hook it into a hole within the metal frame in the dash. It wasn't actually screwed to the dash as we could not get a screwdriver or drill back there. It only hooked on, and would be easy to remove if you know it's there. But the theives could not see it. It worked great! The only problem was that they had stolen the whole car and had plenty of time to figure it out. So the car is found abandoned and sure enough the stereo is gone. The console was torn apart though. They basically peeled back the side of the console to try and figure out what was holding it in. It cost my friend an additional $400 to replace the part. But I sure was proud my contraption worked so effectively given the cost.
Myetball
SmithSR wrote:They tried to steal it, but failed... that's the worst. I say, if you want it so bad, take it and never let me see it again.
Well, based on the area I live in it was probably some stupid Mexicans. They tore apart the column cover and still couldn't get the cylinder to turn. Nobody ever said thieves were smart. If they were they could probably get a job and be able to afford to buy stuff instead of stealing.
Phax
Car: Control dynamics
Myetball wrote:Well, based on the area I live in it was probably some stupid Mexicans. ...
Stupid people come in all races, so do thieves.
Adikt
just buy urself a rottweiler and have him sleep in ur car no ones gonna mess with ur stuff if the see him in there
