sileung wrote:Though it doesn't make sense in terms of physics since there is nothing to ground the static charge, this little device seems to work wonders.
Well... if it works it works. Earlier in this thread I Googled static and antennas and like others have stated... they all seem to promote the reduction of radio static versus static electricity in your car.
However, based on your response that it works... I went searching again. This time I found one advertised as eliminating static electricity.
- Made from lightweight, weatherproof Soft resin, the spoiler not only looks great placed on the ceiling, bonnet/hood or rear of your car, but helps remove anti static electricity too.
Go figure!
In my searching I also ran across a key ring that is supposed to prevent electric shocks from static electricity!
http://www.uxcell.com/black-an....html
And also found a product called the ZAP Absorber:
http://www.arenro.com/car_stat...r.php
Oh well! While it appears you have resolved the problem... here are two other tips I came across: 1) When you open the door to exit the car, grip the metal frame of the door for a couple of seconds before you let your feet touch the ground. The static charge is balanced when you're still seated, when you get up the charge of your clothing doesn't have the opposite charge to hold it where it is. Having your hand on the car frame when get up lets it discharge more slowly. All you need to know is that it works. 2)Open your door, and while still sitting in your car seat, reach up and rest your hand on the (outside) roof of the car before you slide out.
Last... here's an interesting video showing why static electricity, your car, and gas stations don't mix.
http://www.youtube.com/watch?v...lated
Modified by Elton Noway at 7:27 AM 6/18/2009
