WDRacing wrote:Using AntiLag is very hard on your turbo and manifold. They will become extremely hot. Putting unburnt fuel into the exhaust manifold isn't the best option for a daily driver. And is really not needed unless its for a race car that does Autocross or some type of extended Rally racing. Drag racing doesn't require this either. A simple safe Bosst activated N2O system would be much cheaper and safer.
Or like you suggested already a 2 or 3 way rev limiter can be used to generate boost prior to launch. But I believe the MSD 2 and 3 step limiters require use of the MSD 7AL system with the soft touch rev control. Which is a good investment in itself.
Kind of rambling, hope that made sense.
WD
I knew what anti-lag was, but I didn't realize it was the same as Launch mode. I researched the MSD 7AL-2. It came in 3 versions a 4,6,8 cylinder version, do you know what the difference is? Because if I'm going to spend $400 on an ignition system and a 2 or 3 step I might as well get the 8 cylinder version for later 6/8 cylinder applications.
What do you think would be better (granted I will get a knowledgeable tuner) Haltech with MSD ignition or TEC III. I'm looking to have a built KA with the GT3037, and run I'm looking for 300-350whp (15psi) daily and 400whp (20-22psi) with pump gas and alcohol injection on the weekends.
