I was checking out carcraft.com today. One thing that I came across was the dynamics of coating the exhaust system. Most people have heard of coating the outside of the manifold and turbine side of the turbo. The idea there is to trap heat inside the manifold and turbine housing to aid the spooling of the turbine. If you were to coat the inside and outside of, say the down pipe and exhaust system the article says that you would increase the velocity of the exhaust gasses, improving the scavenging of exhaust gasses from the combustion chambers, or possibly in this case, helping to create a small vacuum on the outlet side of the turbine. The other advantage to doing this would be cooler under the hood temps, providing a cooler/denser air charge, and providing a slight relief for the cooling system. Couple this with a well matched turbo, short IC piping that suffers very little pressure loss, and a really stiff BOV that allows for absolutely zero leak off at high boost, and spool up times, commonly referred to as turbo lag, would be greatly reduced, for a fraction of the price of the "after burner", as cool as it would be.
Here is the link for the coatings article:
http://www.carcraft.com/techar....html
