anti-freeze in oil
pmion13
Car: 1990 240sx
KA24E anti- freeze in oil pulled head gasket looks fine anyone run into this
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
you might have a cracked head. i would do a compression test. where the numbers start to change, thats where the crack may be. and you should also try getting the head pressure tested.
DRFT(kinda)
Car: 2005 Nissan Titan.
Antifreeze in the oil is never good and only means one of 2 things. Like jdm_master said it could be a cracked head. I think if the head gasket goes it will leak coolent into the oil as well. Either way the motor is on the fast lane to death.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
DRFT(kinda) wrote:Either way the motor is on the fast lane to death.
STBY
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
You guy's are all WRONG!!!!. This is a very typical problem associated with the timing chain assembly and front cover. This problem was first noticed with the NAPSZ engines of the 80's which use very similar components as the KA24e. When the engine becomes excessive in high mileage over 100,000miles, the timing chain as well as the guides become weak and old. Once the chain is given too much slack. The chain then begins to grind into the front cover where the location of the coolant pump assembly is found. At any given point once the front cover has been grinded into too much, coolant from the coolant passage begins to leak into the oil pan. This is a problem that should be corrected IMMEDIATELY as it will cause hydrostatic locking withing the cylinder and can bend a rod and destroy the valve train....
redtop91
Bigvinnie wrote:This is a problem that should be corrected IMMEDIATELY as it will cause hydrostatic locking withing the cylinder and can bend a rod and destroy the valve train....
jdm_master_X
Bigvinnie wrote:You guy's are all WRONG!!!!. This is a very typical problem associated with the timing chain assembly and front cover. This problem was first noticed with the NAPSZ engines of the 80's which use very similar components as the KA24e. When the engine becomes excessive in high mileage over 100,000miles, the timing chain as well as the guides become weak and old. Once the chain is given too much slack. The chain then begins to grind into the front cover where the location of the coolant pump assembly is found. At any given point once the front cover has been grinded into too much, coolant from the coolant passage begins to leak into the oil pan. This is a problem that should be corrected IMMEDIATELY as it will cause hydrostatic locking withing the cylinder and can bend a rod and destroy the valve train....
and you don't have to SAY IT LIKE THAT!!!. we are not wrong completely because what if that is not the case for him?? how about you wait and see what the outcome of his problem is before you blatantly say YOU ARE ALL WRONG!!!!. you prove a good point, but gee grow up.
pmion13
Car: 1990 240sx
Thanks that is what I was going to check next when I got the head off I noticed that the right side guide was totally gone so the chain was riding on the timing cover. the motor has 190,000 on it
DRFT(kinda)
Hey redtop, what does "STBY" stand for. My interwebz skillz are teh suck.
tjmhillz
Car: 2001 Lexus IS300 Turbo
im guessing standby??
DRFT(kinda)
Thats what I thought, but that didn't make any sense.
redtop91
Nope STBY:
S= Sucks
T= To
B= Be
Y= You
BlazeSilvias
Car: 02 Veilside Celica, 89 240sx, 92 kawasaki ninja 600
well at least you arent retarded. a friend of mine had his friend call me cause she had a problem with her car. she said "i needed antifreeze, but i think i put it in the wrong place" so naturally i asked her where she put it and she said "uhm...there is a cap on the top of the motor, i opened it and put the antifreeze there. and when i started the car it went bang" i simply shook my head and handed the phone back to my friend.
i should have said "HERES YOUR SIGN"
DRFT(kinda)
BlazeSilvias wrote:she said "i needed antifreeze, but i think i put it in the wrong place" so naturally i asked her where she put it and she said "uhm...there is a cap on the top of the motor, i opened it and put the antifreeze there. and when i started the car it went bang"
That is classic reason why clue-less chicks should not be allowed near anything expensive.
Bigvinnie
We can wager a bet through paypal if you like I have $50 dollars that it is the timing chain and assembly. I've worked on plenty of high mileage KA's and NAPSZ motors to know obvious problems. Fact is the timing chain assembly will go before the head gasket leaks. Compression starts to go down the crapper if it was the headgasket as well, you would notice the power loss before the leaking, if it were the head gasket.Plus if the leaking was coming from the head you would start to hear rod knock......
Bigvinnie
No that isn't. You agree with others that the problem is coming from the head, or gaskets. I claim that this is a timing chain issue.
Bigvinnie
pmion13 wrote:Thanks that is what I was going to check next when I got the head off I noticed that the right side guide was totally gone so the chain was riding on the timing cover. the motor has 190,000 on it
No problem good to know that I could actually help....$50 dollars anyone?????
