But shouldn't the motor continue to try? It actually quits where the antennae stops.zer0c123 wrote:You need to buy a new antenna mast, which can be found on ebay. They should come with instructions on how to replace. It's somewhat of a pain to replace, because you might have to remove the entire antenna motor assembly. Most likely the plastic rack inside has snapped so that's why it won't retract all the way.
That's just it. The motor stops when the antennae stops. I don't think it's a mast problem.I know the mast on my coupe is messed up because the motor works, but the antennae doesn't.zer0c123 wrote:Yea, the motor will continue to move after the antenna stops. This is because the plastic rack (with gear teeth) is broken. It's trying retract or unroll the entire length of the plastic rack, but it can't now because it's broke in two. Applying WD-40 won't help.
I had the same problem when I first bought my 240. The previous owner thought that the sound of the motor after the antenna stopped moving was a rear speaker malfunction.
