antennae grind Q45
zekedog
Car: 1995 Q45T
My power antennae sounds like a margarita mixer when going up and down. Anybody know if it can be lubed and how? Thanks.
Kevin/Nashville95 Q45T Black 50k
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You can take the tail out and lube it with a lithium grease, but I bet that will not cure your problem. Most likely, it is your motor failing. The tail and drive gears are nylon, so do not require lubrication.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I bet the belt is breaking, the motor doesnt really fail that often too my knowledge...
Get a replacement mast, and take care of it that way.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Layla's made terrible noise. When I opened the side, the aluminum tube is broken in half. The shaft and motor are fine, but the tube causes it to bind. I just lowered it, and unplugged it. The reception is about 10% worse, but much more acceptable, than an antenna half way down.
Jeff - UGM.
