Antenna wire replacement
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
PimpG
Hi guys I just bought an 07 nissan versa base model, only has A/C. Problem I cant figure out is I got it from an insurance auction and the radio was stolen as well as half the interior.
Ive got the interior for it but the radio wires and antenna wires were cut and I re wired the harness for the speakers but the antenna wire is un repairable.
Can anyone help me out on trying to replace the antenna wire from the back of the radio? Does it have to be replaced all the way back to the antenna mast itself or is it just a small seperate wire that i can replace?
it sucks driving it without having a radio functioning
Thanks to everyone in advance-G
PimpG
come on guys, like 20 views and noone has anything to say
nick425
Car: 2008 Versa S
What kind of head unit do you have? Is it stock or aftermarket? If its aftermarket, you can buy the harness at Best Buy or anywhere online with a Google search... If it is the stock head unit, it is simply just part of the main existing harnesses that came with the car. Quick search = http://www.fadfusion.com/selec...05342 Take her easy amigo.
PimpG
I dont know what it had in it originally, when i got it from the auction it didnt have a radio in it and the wires were cut behind the dash as if someone just cut the harness to steal the radio. I want to put an aftermarket radio in it but I cant tap into the antenna lead for the ground or for actual radio stations. I just want to know if I can replace the factory antenna wire easily or if I have to replace the entire wire from the front to the back.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
Sorry for the delay on replying. There is a sub-antenna inside the dash that runs from the left side pillar to the radio. You'll only need to replace that. Part number 28241-EL000.
PimpG
thank you very much. You wouldnt happen to have a price for that wire off hand?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
No idea on the price. I'd try a local dealership or one of the good ones online like nissanparts.org. They'll give you a 25% discount if you mention you're from NICOclub (they are a site sponsor).
Double check the part number if you talk to them, just to be sure. Better safe than sorry when you open the box.
PimpG
thanks for the professional response. You wouldnt happen to know how to replace the wire would you?
Return to “Versa Technical Discussions”
