Antenna
RQ
Car: '97 J 30
Has anyone used an aftermarket universal antenna to replace the factory unit on a J30? Crutchfield says that theirs will not work so I'm wary of any of them now.
jdurrty
Car: j30
RQ wrote:Has anyone used an aftermarket universal antenna to replace the factory unit on a J30? Crutchfield says that theirs will not work so I'm wary of any of them now.
I dont know about you, but my antenna has been broken for 3 years now and i still get awesome reception without it both with the stock cd player and with an aftermarket one.
RQ
Car: '97 J 30
Well YEAH with a cd player I guess you would! How's it work with the radio?
yodawill2000
Car: 94 Infiniti J30
If I recall theirs also a antenna in the OEM Windshield.
jdurrty
Car: j30
RQ wrote: Well YEAH with a cd player I guess you would! How's it work with the radio?
someones a jokester. it works great with the radio, even 30 miles outside the city it is crystal clear
puck
Car: 1997 Infinity J30
I used one off ebay. I had to spice the wires and drill a hole in the mounting bracket to get it to fit. It works. Don't make the same mistake I did tho. Make sure you disconnect the battery before you start working.
driverdriver
Car: NICO's longtime resident Canuck!!!
Is the antenna actually broken or it can't go up and down but you can hear the motor?
I don't know if a product such as jig-a-loo is sold in the US
http://www.jigaloo.com/ca/e_products_jigaloo.php
I managed to get my antenna working again smoothly with this product. I had tried WD-40 and Liquid Wrench before, but my antenna only worked for a short time.
yodawill2000
Cant seem to find it in a US location Driver,But I would sure like to try that stuff out !!!
RQ
Car: '97 J 30
I got some at Home Depot and used it and it is great stuff. It worked wonders on the window tracks!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
No disrespect but if you can't afford the $40 shipped OEM new antenna then you can't afford the J30. I was in your shoes once when I had a 1991 Q45. I tried to use the antenna from a 1997 Q45 and it didn't look good.
So get only the parts that fit the car!
RQ
Car: '97 J 30
Sorry Paul but the POWER ANTENNA is $231.00 at InfinitiParts.com. I don't want just the mast or a non power unit. I found a used one for $65. that I'm going to pick up tomorrow.
RQ
Car: '97 J 30
Actually I thought that I got the Jig-A-Loo stuff when what I really got was RZ-50 Window and Door dry lube but it still works great
driverdriver wrote:Is the antenna actually broken or it can't go up and down but you can hear the motor?
Infinitiguy19
Why not get one from a junkyard then?
RQ
Car: '97 J 30
Paul Wall wrote:Why not get one from a junkyard then?
That's what I'm doing and they want $65 for it
1994 infiniti j30 190+
Car: 1994 Infiniti J30
1990 Ford Ranger XLT Sport Limited Edition
wow i got a new antenna motor for mine and it was i think 15 or 20 bucks 65 dollars i would just get a new one or not fix it at all.
Infinitiguy19
Yeah bro they are taking you for a ride if they want $65 for it.
If I were you and they wouldn't negotiate I would remove the parts that you need from the assembly then ask them how much they wanted.
