Antenna Switch for 97 Q45t
smalcom
Car: 1997 Infiniti Q45t
I had an external XM receiver installed in my 97 Q45t that feeds the signal into the standard radio via an FM frequency (wired into the antenna circuit, not wireless.) Naturally when I turn on the radio, the antenna rises automatically.
Is it possible to wire in a switch that would let me retract the antenna when I'm using the XM receiver and raise it when I want to use the broadcast frequencies?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Listening to satellite radio signal on an FM modulated radio is like using the bottom of a coke bottle to look through Zeiss binoculars.
But no, the antenna is controlled by the head unit. So if you listen to FM (which is what your are doing), the antenna stays up.
smalcom
maxnix wrote:Listening to satellite radio signal on an FM modulated radio is like using the bottom of a coke bottle to look through Zeiss binoculars.
Have XM so that I don't have to constantly search for stations as I travel from region to region. Not looking for sound perfection in a car, just decent music withoiut the hassle of searching local stations. Not everyone wants to blast other drivers out of their cars.
qship96
Car: 1996 Infiniti Q45
Did you move from Frederick to Reisterstown?
smalcom
qship96 wrote:Did you move from Frederick to Reisterstown?
No. Moved from Delaware (Rehoboth Beach) to Reisterstown.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Understand. Just converting digital to analog FM, then imprecise tuning and demodulation of the converted FM signal intorduce all kinds of frequency and signal to noise ratios and stereo separation vs. frequency.
Anyway, if you study the output from head unit, you could probably insert a switch to defeat the antenna extension when switched to FM.
If you don't have an auxiliary CD-ROM deck, probably a whole lot better to try and utilize that input. Even the cassette input might be converted.
smalcom
maxnix wrote:Understand. Just converting digital to analog FM, then imprecise tuning and demodulation of the converted FM signal intorduce all kinds of frequency and signal to noise ratios and stereo separation vs. frequency.
Thanks for the tip. Yes I do have the CD changer in the trunk, so I will have to investigate the output and see if I can isolate an antenna line.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Try an cassette adaptor. I use one on my cars and they sound really good to me-almost CD quality and a TON better than the FM modulator.
Seriously, try one, $20 and I bet you'll love it. (also solves your antenna problem as the antenna stays down when on cassette).
smalcom
bullittandy wrote:Try an cassette adaptor. I use one on my cars and they sound really good to me-almost CD quality and a TON better than the FM modulator.
Sounds like a winner. Will try it. Thanks for the tip.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
That will solve your antenna problem. Similar equalization problems, but no demodualtion and better stereo separation.
smalcom
Thanks to all. The cassette adapter arrived today. Found it on ebay for $.99 plus shipping ($3.99) and you're right. The sound is 1000% better, and the antenna stays down. Only problem is the slight ticking sound (barely audible) from the player.
bullittandy
Glad it worked for you and thanks for posting back with results-very helpful for future searchers.
If ticking is bothersome then try a namebrand from Bestbuy or equivalent to cure, $20 max.
smalcom
bullittandy wrote:Glad it worked for you and thanks for posting back with results-very helpful for future searchers.
Ticking solved. I "rewound" the cartridge. BTW this adapter does have the XM logo on it, although it may be counterfeit.
