Postby
insomnia816 »
https://forums.nicoclub.com/insomnia816-u143568.htmlMon Nov 30, 2009 8:45 am
Just want to share with you guys about the Rogue's Antenna. Since I don't like the OEM antenna that came with the car. So I went to eBay and didn't find what I was looking for. Later I did some research and came across a local merchant that sells the shark fin type antenna to match exactly my car's paint. Altough its not a cheap replacement, but its definitely worth the look. I just got mine ordered.
Postby
THawks »
https://forums.nicoclub.com/thawks-u147747.htmlMon Nov 30, 2009 2:26 pm
Good looking out. I will have to look into getting myself one of these after the holidays. Thanks for doing the legwork and showing that there is an option out there.
Postby
philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.htmlTue Dec 01, 2009 2:20 am
The factory antenna with the large rectangular base contains the SAT radio antenna and amplifier. Unless the replacement contains all these features, you risk losing your SAT radio.
The regular antenna (non-SAT radio equipped Rogues) can be easily fitted with any aftermarket antenna.
