countrygrl wrote:My 1993 Q45 has a rear power antenna. I can hear the motor running, but the antenna is loose at the base and feels broken. My FM reception is sporatic, and so is my stereo. When I am listening to a stations, sometimes is just goes quiet. Cassette does not work.......Countrygrl
The antenna is only for AM reception, the wires built into the rear window are for FM reception so the problem with your stereo is not antenna related. If you don't listen to AM get the antenna seated in the down position and unplug it. Most of the problems with broken masts occur when it gets frosty or icy and binds when raising or lowering. Access to the motor is pretty easy. Just remove the trim piece from the trunk (plastic screws) and you'll see it all. If you're hellbent on replacing the mast they're available on ebay for about $20 plus shipping. It sounds like you may be ready for a new head unit and amps which are mounted to each of the 4 speakers. There's a 93 being parted out in the parts forum now which could be a good source for these parts.
To get to the head unit pry off the trim surrounding the shifter and then there's 6 screws to remove to get the trim piece surrounding the head unit out- 2 below the shifter, 2 below the ashtray and two above the ashtray once its removed. Once the trim is off there's 4 bolts holding the Bose head unit in place. Easy stuff! Good luck.
