Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Mon Jun 01, 2009 3:26 pm
Some PF have a diversity antenna. My '01 SE does. There are TWO antennas. One is the regular mast, the other is silk screened onto the windshield. The radio is smart enough to pick the strongest signal. My mast is fixed, notretractable.
The '01 FSM shows that the antenna mast is replaceable from outside thetruck. You might try remove and replace the existing antenna that way to seeif that fixes it. It will also let you know if the plastic gear teeth at the bottomof the mast are messed up.
The antenna on my '87 'vette stopped going up all the way. I researched iton the net, and some wag had said: they hung the antenna from the factoryroof and built the whole car around it. HE WAS RIGHT. It took a LOT of hours toreplace it. Like 20. The '88s had an mast that was replaceable from outside,I installed an '88 mechanism.
The net is that if you replace the mast, it will probably be just a couple hours work.
Slickroger: note the above.
All: I think there are just 2-3 manufacturers of electric antennas. It wouldbe great to know who made them for Nissan when and for what models.
