Yeah that sounds good but I was told that you can't do that with the Power Antenna ones.Pathfound49 wrote:Just unscrew the antenna and leave the remaining mount in the fender.
I haven't checked for blown fuses but now that you bring that up, where are the fuses?Towncivilian wrote:Have you checked for blown fuses? Maybe the fuse blew for the power antenna. If it's okay, have somebody stand near the antenna to see if they can hear the motor operating.
Ok, Thanks.Towncivilian wrote:There are fuses behind the driver coin tray and in the engine bay on the passenger side. But since you hear the motor working I wouldn't bother to check the fuses.
Ok, thanks.04pathse wrote:Most hardware stores such as Ace, Lowe's, Home Depot, etc. carry many different sizes of plastic plug inserts, you should be able to find something that will fit.
No it won't go down.Chuck Tribolet wrote:Can you straighten the antenna enough to push it down, then unplug it so it doesn't go back up?
And there are rubber plugs used in the electonics biz that might work too. Radio Shack MIGHT have them, Mouser
Electronics for sure.
