Antenna doesnt work....amps disconnected???
Post all your Nissan electronics, car audio and stereo questions here!
240Knightrider
ok, i installed new speakers in my front doors. I believe the amp has been disconnected because I have five spliced wires hanging out.. I know two wires connect the speaker and they work...but my antenna doesnt work and I cant figure this out. there are three wires left. Does anyone know how to wire it to make my antenna work again. When I connected two of the other wires the antenna worked but it look right to me. Thanks in advance
johndabrit
Car: 91 240sx LE modified air box, hi-flo cat, 300z fuel filter, blown speakers
240Knightrider wrote:ok, i installed new speakers in my front doors. I believe the amp has been disconnected because I have five spliced wires hanging out.. I know two wires connect the speaker and they work...but my antenna doesnt work and I cant figure this out. there are three wires left. Does anyone know how to wire it to make my antenna work again. When I connected two of the other wires the antenna worked but it look right to me. Thanks in advance
You would still have five wires if the amp was connected. The two wires that make the antenna wire work NEED to be connected together. It seems that they run through that plug but for what reason i dunno. The other wire.... well i dunno what that is for either. COULD YOU DO ME THE FATTEST FAVOR and tell me the wiring color scheme for the positive, negative, and the two that power the antenna? I just got new speakers for the front and i need to cut the plug off the harness and wire direct. I dont know which wires are what. You said you know which ones are what besides the one left over. Could you tell me which is what? thanks in advanceJ
