Antenna Adapter for Diversity Antenna - 12v Power Hookup
tonewheel
Car: 2007 M35X
Gang,
I installed the Peripheral Electronics iPod and HD radio adapter (PXAMG and HDRT) modules. The install went well, pretty simple actually.
I had an initial problem which was explained to me by manager of the online store where I bought it from. The problem was that while the iPod and SAT radio functions worked fine, the HD AM and FM radio didn't work at all. Turns out that there's a loose blue wire coming off of the BAA36 antenna adapter. There were no instructions for that wire, so I (wrongly) assumed it was a ground and left it alone. What it is, I was told, is a 12v ACC power hookup for the diversity antenna. Without that powered up, the radio won't work as it is supposed to. So...
I am going to have to find a 12V switched power supply for that. While the kit installation was simple, with harness connectors, this 12V hookup is a bit more challenging...for me, anyway. I can cut/splice/tap/etc., but have absolutely no clue where to find a 12V power supply. I suppose I could run something to a fuse block somewhere, but honestly I would much prefer to splice into a wire that's already handy and in the vicinity of the radio.
Any suggestions would be GREATLY appreciated. Thanks!
tonewheel
Car: 2007 M35X
No one?
tonewheel
Car: 2007 M35X
OK, no responses so far.
So, perhaps someone can look at this page I found: http://www.nicoclub.com/articles.php?id=220509
Should I look for that purple wire on the back of the radio harness, and tap into that for 12V ACC?I need to get power back to the diversity antenna.
Thanks.
mcdoken
Car: M45
Why not tap into the power supply for the cigarette lighter? It's easily accessible - I connected my radar detector there.
tonewheel
Car: 2007 M35X
Thanks!
Not too swift with the electrical stuff. I appreciate the help.
