OKVersa wrote:Well, I spent 23 minutes on the phone today trying to figure out why others are getting their TPMS problem fixed, but my dealer says there is no fix. The representative I talked to says that she doesn't find any other complaints on the TPMS in the Versa.
I actually don't think there's a fix yet. Other folks have had sensors and whatnot replaced, but we don't really know if the problem is truly solved. When they've done a re-register on mine, the problem goes away for ~1200 miles. If they'd replaced a sensor or two at the same time, I *still* wouldn't know if the light is out because of the re-register (and will come back on again in a couple of months) or if the sensor replacement really and truly fixed the problem.
One poster got his dealer to actually disable the TPMS itself, which Nissan probably won't approve as an overall remedy.
I am not sanguine about Nissan fixing this based on calls to their 800 number. I like CowboysFan 87's solution: Drop a nickel to the NHTSB. This is a federally-mandated piece of safety equipment that is faulty. Damn right Nissan should fix it, and they'll be a LOT more interested in finding a solution if the Feds get on their case about it.
http://www-odi.nhtsa.dot.gov/
Next time mine triggers, I intend to do just that. I'll follow it up with a letter to Nissan USA...in my experience, physical mail tends to get a lot more attention.
I've noticed there are already three TPMS failure reports on the NHTSB.
Ron
