another z32 brake question
jdubau55
i did a search so please dont say " use the search tool". what is the diameter of the z32 rotors? will i have to have bigger wheels to fit them or will the stockers be ok?
C-Kwik
The problem of fitment is usually not the diameter. It's small enough to fit under many 14" wheels. The problem that most will run into is the caliper sticks out farther outboard. Offset is more critical.
As far as stock wheels, the S14 SE wheels will fit. Only some of the 91+ S13 SE alloys will fit(26 mm wide rotors only). And the 89-90 teardrop alloys will not clear. None of the steel wheels for any year will fit. Not sure if non SE S14 alloys will clear or not.
The Z32 rotors are 11" in diameter btw.
jdubau55
thanks for the info. so will the stock offset work. like if i bought after market wheels with the stock offset would it work? heres the wheels im gettin just to let you know.
http://cbwheels.com/subzero.htm
i want to go with 17's but i want the lightness of the 16's and the 16's will be cheaper.
C-Kwik
OK, it just dawned on me that I said it might fit under 14" wheels. I actually meant 15". Although there might a 14 inch wheel that might clear, the stock 15's on the DOHC S13 SE may or may not clear depending on if your wheel has a protrusion behind each spoke. Teh wheel slook ehte same on the outside, but for some reason Nissan released two versions of the same wheel.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
If it is the offset that makes the wheel not clear the caliper, you can pick up some H&R wheel spacers from http://www.optauto.com .
My question is if i keep my 4 lug and have someone drill the correct holes in the Z32 rotor, what all hardware do i need to get off the Z32 car? Will my caliper bracket work or do i need to get that?
jdubau55
ok heres the deal. i am lookin at the heavy throttle 4 corner brake upgrade. i was wonderin if: 1st, does the 26mm calipers come in aluminum, 2nd, does the aluminum caliper help disapate heat better, 3rd, if so is it noticable, 4th is the 30mm rotor a BIG improvement over the 26mm. sorry for all of the questions but if there isnt a big difference i would rather save the 70 bux and use that for that big APC sticker for my windshield ;) .
jdubau55
thanx for the info. i think im just gonna go with the 26mm kit. i have no idea if my brakes are fading. i dont even have the car yet. but i am debating on what to spend my extra dough on after i egt the car and the wheels i want.
jdubau55
yeah im not sure what i wanna do yet. i just know i am gettin wheels as soon as i get it. any suggestions. i will have about 1000 after i get my wheels. what would you suggest for best performance. i am thinkin between exaust, some suspension stuff, maybe CF hood, etc.
jdubau55
nah. i am not puttin any work into the ka24e. i am DEFINITLY gettin the sr swap. this has been my dream ever since i got the first gran turismo and foung the silvia. and now its feasable. yeah i want the car to basically be the **** when the sr goes in so that all my money can go into the motor. race over rice.
as far as suspension goes. i can get HA's for less than 1g right now. should i go ahead and get that big upgrade now that i have the dough or wait. if i waited i think i would put the 1000 into STB's, bushings, anti-roll bars, maybe exaust too.
jdubau55
the HA's i saw actually were more like 1050 but i saw that at i-m-racing.com and then i believe at enjukuracing.com they have them for 1100. thanx for all this info.
