Interior:
Rear Center Hatch Panel Lower and Upper One on Hatch
New Rear Hatch Release Cable
Fixed Hatch Light Problem
New T-Top Finishers
New Jack and Spare Tire
Repaired Power Seat on Drivers Side
New Brake Light Harness
Repaired All Wire Splicing
Replaced Most Of The Interior Bulbs
Replaced All Fuses
New Double DIN Radio Bezel
Installed Bluetooth Microphone for Future Head Unit
Exterior:
2 Used Rear Rims to replace bent and curb rash ones
Used Right Rear Lower Control Arm
Rear Right and Left Wheel Bearings
New Brake Dust Shields
New Rear Bushing (Energy Suspension)
New E-Brake Pads and Spring Kit
New Rotors and Brakes
Deleted Head Lamp Washer System and Replaced 3 Pump WW Tank with Used 2 Pump System
New Windshield Cowl
All New WW Lines to Front and Back
New Front Ambient Temp Sensor
Used Front Aluminum Reinforcement Bar and Supports
Used JDM TT Front Bumper Cover
2 used Headlamps (Cleaned and oiled up to brand new)
Used Center Nose Panel with "Z" Emblem
New Drivers Side Door Handle Finisher
All New Locks and Keys
4 New Tires
New Battery
New Positive and Negative Battery Cables (Battery to Starter and Battery to transmission Ground) PIA!!!!
New Back Up Camera For Future Head Unit
Still Needs:
Safety and Emissions Test
Paint Job and minor body work
Transmission Pan Gasket and Filter
All Other Fluids and Filters Changed
I Think I need A New PTU. Not Broken Yet but I am sure I have the Old Style
New Coils
Front Suspension Bushings
120 K Timing Belt and Pulleys done
Radiator doesn't look so hot. Not sure yet
Leather Seat Covers (No tears in drivers. Passenger side look like it got wet at some point and the center of the seat shrunk and pulled the corners all out. Faded too)
Front Drivers Side Floor Mat
Clarion NX602 Head Unit
New Speakers (2 Fronts work. 2 Rears Nada. Bose so likely blown amps)
Here she is out of the garage for the first time since I brought her home:
a** Shot:
!@#$$#$#^ Up Lower Control Arm:
Can you spot the aftermarket power lock actuators that had the door locks completely messed up?
I just can't get over how excited I am to finally be driving it by mid-July. It is no small amount of thanks either that I pass on to everyone here who has directly or indirectly helped me get this far. Many a night I have been browsing and searching on this forum and others to come up with solutions or How-To's. My hat is off to you all. THANKS!!!
And thanks For Looking!
Evan
