Another wiring issue... Yes I've searched
2ndcar
Car: 1991 240SX White 1991 240SX Gray 1995 Civic
Long story short my ca wiring is a bit scrambled and i'm trying to figure out what this one plug leads to. on the ka harness it has a yellow w/ green stripe and yellow w/ red stripe. the yellow with red goes to 4th gear i believe and yellow with green to 5th or something like that. what does it go to on the ca harness? one is connected to Neutral and the other was an open wire leading to nothing please help
Thanks
2ndcar
Ok did a bit more researching can anyone tell me if this sounds right? This is based off of a DOHC KA
Use................................Color of wires
Alternator......................White w/red stripe, thick white for plug, single white and single black
Oil pressure switch........Yellow w/white
Starter motor.................Black w/yellow, Black w/red
Speed Sensor................Yellow w/Black, Yellow w/blue
Back up Lamp Switch.....Yellow w/red, ground
Neutral Pos Switch.........Green w/yellow, ground
5th Pos Switch...............Yellow w/blue, ground
4th Pos Switch...............Green w/yellow, Green w/blue
I'm trying to sort out the wiring for this to make sure its correct the ca harness that i received was already cut and one of the connections didn't match up for me.
On my stock ka harness it was the plug that was under the fuse box. The Yellow w/blue and Yellow w/red led to it.
But on the harness that i had it had a four pin plug 3 out of the 4 were lose wires and the other went to the 5th position switch.
Any clarification would be greatly appreciated
