another wire question...key switch wires
nismoracer22
ok hopefully the last question i have.... there are 5 wires comming down from the key switch and plug into my turbo timer harness. my question is what is the color of the wire or wires that only have 12 volts when the key is in the start postion. to clearify: i know there is a wire that is always getting 12 volts im asuming it would be called the battery wire, and the is a wire that gets 12 volts when the key is in the ignition spot aka ignition wire, but what is the wire or wires that gets that 12 volts in the start spot? i just need the color of the wire from the key switch or the color of the wire on the hks turbo timer harness. its times like these i wish i had a volt meter or knew how to use one. haha. thank you.
Silvia007
Car: 93 Nissan 240SX SE Fastback
So you're looking for the "starter" wire correct?
nismoracer22
i believe so...i hope it is called that.
nismoracer22
ok i found something...there are two starter wires....is this correct? i am getting two differant things from differant places. one says black/white the other says black/white and also black/yellow anyone know for SURE? and by sure i dont mean looking it up from the same websites i looked at. if anyone has a book or something.
Wolf240SX
Car: Tuning my car, working on friends cars
the simpilest way to determine which wire is which is to use a test light or volt meter. Measure each wire with the ignition off, acc, and on position. The wire that has 12 volts when the key is off is your constant. The wire that gets power when the key is in the acc position is your accessory wire. and so forth. I know in the apex turbo timer red gets hooked up to white with red strip. Blue goes to blue and green goes to balck with white stripe.
nismoracer22
well the only problem is if you look at the first post i do not have a voltmeter nor do i know how to use one.
nismoracer22
OK this is what I got so far...white/red battery, black/yellow starter, blue accessory, black/white ignition, black/green ? now the volt meter and the know how would come in handy. someone know bout this black/green wire...second starter wire maybe? i hooked the two wires black/yellow and black/green and the push botton works but now i have to somehow bypass the key. only problem with that is if i bypass it then i can not turn off my car. haha. any ideas?
marshun
i dont think you should bypass the "on" switch because it sounds like it would make it so anyone could start the car.
i'd say to just tap the wires you need to so that you would still need the key to put it into the on position and have the choice of turning the key or hittin the button. :)
nismoracer22
hummm kill switch eh...didnt think of it....now for the wires for that. oh and about the wires for the starter. there are two wires for the starter kinda like a loop it seems. both are positive. so now anyone have any know how on kill switchs? time for a new topic i guess
