IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Wed Jul 14, 2004 6:16 pm
so, today my two cd drives decided they wanted to stop behaving. the actual event that caused this could have happened up to a week ago. i cant pinpoint it. [secondary master- dvd-rom, secondary slave- cdrw]
KEEP IN MIND- THE CDRW FUNCTIONS PROPERLY IN NERO.
basically, heres the problem. i inserted an audio cd in the hopes of duplicating it. i close the drive, and bam! no autorun, and no media identification [no disc name or type displayed in explorer]
ok, so i click on the drive, and instead of it opening WMP, it opens the disc [lists tracks]. also, in properties, there was no recording tab.
so i figure it was a bad connection or something, and i removed the two drives from device manager, and removed the secondary ide controller also.
i reboot, enter BIOS, and disable the secondary ide controller.
boot to windows to clear drivers, and then shut down.
open case, remove the ribbon and power cables from both drives and motherboard. reconnect. reboot. enable secondary ide controller.
let windows reinstall drivers. reboot.
now, the cdrw and dvd drive will STILL not autorun or identify the media in the drive.
so, i edit the registry to find out that the drive is incorrectly identified as non-recordable [the cdrw] [a value of 3, as opposed to 1 for cdr and 2 for cdrw] key -
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives\Volume{eb726c01-d5e8-11d8-9ae9-806d6172696f}
ok, so i corrected that which brought back the recording tab in that drives properties.
i also moved the drive to the primary ide with no luck.
the lasting problem- why did autorun suddenly stop, and why wont the drive identify the media to the operating system??????
i fix computers all day, and this one has me stuck. the drives still WORK, just not the way they should.
