so about a month or two after i installed my stance coilovers im starting to hear this noise coming from the rear. it comes from both the right and left side but you can hear it alot more from the right. here are the symptoms:
the car makes a loud "clunk" after i hit bumps in the road.
going around right hand turns ( not as much load on the right rear coilover) it clunks like crazy.
you can hear it just a little bit just by pushing down on the car when parked.
ive gotten underneath the car a couple times to just look over everything to see if anythings loose but its all tight. im thinking that it might be my subframe bushing? ive searched for quite a while and that seemed to be alot of people's "clunks" they have. should i get under the car and watch the bushing as someone pushes down on the car?
thanks guys
