another wheel/tire question
damonross
Car: 1997 Infiniti Q45
I am looking to put 20" wheels on my 97q w/ 225/35/20 tires. My question is does anyone recommend 20 x 8.5 or 20 x 9 front/rear?
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
a 245-35-20 is going to be a MCUH better tire choice. 225 is way too skinny...
damonross
Thanks for the reply. Will the 245 leave enough room to avoid any rubbing? Also, do you recommend this because of a smoother ride or something else?
Thx
elwesso
2007 BMW M Coupe
it will give you a better ride, but MORE IMPORTANTLY it will give you the extra load capacity you need. People tend to forget that the Q weighs about 4000lbs (any year), and you cant be as frugal with tires!!!! The front tires on a Q45 go through hell and back over their lifetime compared to even a car that weighs 500lbs less!
Youll be able to get 245s without rubbing NO problem... Just be careful with your offsets!!
Are you wanting to run the same size all around, or are you wanting to run a staggered setup....??
damonross
i'm glad u asked. I'm wanting the same size all around. Don't want it sitting higher in back than front. I don't have any knowledge of how offsets work so any info would be appreciated. What I don't want is that look where the wheels look like they are sitting too far in under the fender.
thx
damonross
by the way, the wheels i'm getting are Arelli Geneva's 20".
thx
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
damonross wrote: same size all around. Don't want it sitting higher in back than front. I don't have any knowledge of how offsets work so any info would be appreciated.
Do a lot of reading at Tire Rack and the tire manufacturer's web sites.
Try to stay near 20 lbs. for the wheel weight alone. Be sure the wheels are strong enough also. For real world roads and highway travel, there are better choices.
Don't confuse static appearances with dynamic performance.
elwesso
2007 BMW M Coupe
damonross wrote:by the way, the wheels i'm getting are Arelli Geneva's 20".
thx
Can you post the specs.....? would assume youd have them handy... We can just tell you how theyre gonna fit, and recommend based on that...
Just because you run a staggered size doesnt mean your back end is going to look higher.
damonross
Sure..the following link shows the specs :
http://www.ultrawheel.com/pdf/rims/ACF35AA.pdf
let me know if you have trouble opening.
damonross
The pdf i posted only shows 20x9 but they also have 20x8.5 supposedly. Don't know why that size is not included on the spec sheet.
damonross
this link contains specs for 20x8.5
http://www.1010tires.com/wheel...eneva
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
damonross wrote:this link contains specs for 20x8.5
No weight, no strength.
Be very afraid.
damonross
are you referring to any specific size or this particular wheel in general. or because the site doesn't list the weight.
elwesso
2007 BMW M Coupe
Ok for the 8.5s they either offer a 20mm or 40mm offset.. Using the 20mm offset wheel all around should fit VERY nicely. No rub and will have a nice flush fit...
damonross
so you recommend 20x8.5 on front & back with 20mm offset on all?
thx
elwesso
2007 BMW M Coupe
yeah that would fit great...
damonross
Thanks for the info.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Those are REALLY cheapo wheels, I would consider something else if I were you. I bet you have big issues with balancing and eventually bend one of them.
Try to find a set of FX35/45 rims in 20" off someone, OEM are much better and to get OEM quality you will need to spend more like $700 per rim or better in 20".
You might have found the best bargain in the wheels but my bet is these are cheapo weapo rims.
damonross
well, the rims arrive tomorrow..however they sent a 40mm offset!!! Any info on what to expect as far as fit. Should I be prepared to send them back.
thx
Falkdesigns
Car: 1998 Q45t ~ EXE
Send 'em back. +40 is near OEM offset and will be sunken in about 2".
I have 19x8 +20 and 19x9.5 +20, it's flush with the fenders like Wes mentioned. I had staggared 18's about a year ago, and they were +40, I had to use bolt on wheel spacers to make them flush. And staggared offset doesn't make the back wheels sit higher, just wider
Q_SHIP
Car: 1999 Q45T with a billion miles.
Cheap wheels suck. I rolled mine for 2 summers and they are trashed. Bent and shaking. I would rather be stock than dealing with that crap.
damonross
so I assume I need 20mm wheel spacers?
Falkdesigns
Screw that dude, get what you paid for. Send 'em back, spacers are fine, but you'll end up spending close to $200 for spacers. Just get what you ordered in the first place.
elwesso
2007 BMW M Coupe
Falkdesigns wrote:Screw that dude, get what you paid for. Send 'em back, spacers are fine, but you'll end up spending close to $200 for spacers. Just get what you ordered in the first place.
