whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Sun Feb 10, 2008 5:26 pm
See that is where most people go wrong. A wider tire doesnt increase contact patch one bit, it simply changes the shape of the contact patch. The only thing that will increase contact patch is the addition of more weight to the vehicle.
I could sit here and go on and on, but heres a copy and paste from the Tire FAQ loacted at the top of this sub-forum.
"Think about your tire as a balloon (more accurate than most people think) holding the weight of your car up. Now, if you place a balloon on the ground, it has a certain area that contacts the ground, this is the 'contact patch', now you can make the patch wider(wider balloon) but the total rear remains the same, because the pressure on the balloon is the same.
Now, what does this mean to YOU? It means that since the same amount of tread is in the contact patch area between either tire, 'grip' should be the same. Thusly, the only things affecting grip(since the area of potential contact is the same) are tread design and friction(tread compound) and finally how well the suspension does a job of keeping the tire in optimum contact with the road surface.
Unfortunately it is not that simple. A wider tire does have some benefits over it narrower counterparts, with a wider contact patch comes a bit better lateral stability(to a point, lateral stress doesn’t vary THAT much between narrow and wide tires), but sacrifices some ride comfort, and less noise cancellation(in theory). This can both generate quicker turn-in and, since the treadblocks are wider, less tread squirm which can increase total available cornering force. Also of note, a wider tire generates more rolling resistance than a narrow tire."
I couldnt have said it better.
