Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sat Oct 16, 2010 9:32 pm
Just pull the hose from the rail and let it spew... if you're planning on replacing fuel lines cut the one feeding the filter so the gas will spll closer to the ground. Either way it's not a big deal as long as everything is ventilated, you're not smoking, the gas doesn't get into the cylinders, and you wipe it off of the paint fairly quickly. Be sure to loosen your gas cap too... that will release some pressure.
Heath
