StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Mon Apr 02, 2007 4:56 pm
In another thread, one of the members here advised me that timing CAN be changed on the VK45, but it must be done with a CONSULT II.
So I asked my dealer's service supervisor if he'd bump the timing on my 2005 Q45 by two degrees to 14 degrees BTDC.
When the car was returned to me, the tech put a small adding machine type printout slip from the CONSULT II in my cupholder. I can't find it now, but as best I can recall, the only number on it was a "2", which I thought strange at the time. The service supervisor states that is all it will display, the amount increased. Since then, I notice that the pedal seems a little "soft" and power seems down a little, the exact opposite of what I expected, and mileage is slightly down.
In my long experience working on cars, bumping timing a small amount by 2 degrees isn't counterproductive, but rather improves power, throttle response, and mileage, albeit only a small amount. It's usually a minor tweak, rather than a major improvement, but every little bit helps. My experience has been that a series of small improvements will accomplish as much or more more safely and efficiently than attempts to make major changes which can sometimes compromise other factors.
I'm wondering if the tech or the CONSULT II actually REDUCED the timing by 2 degrees, or worse, dropped it to 2 degrees BTDC rather than increasing it by 2 degrees from 12 degrees to 14 degrees.
I'm taking it back in Wednesday to have him re-check it.
Any thoughts or comments from anyone familiar with CONSULT II and re-setting ignition timing on VK45?
I appreciate any input I can get before I take the car back to the dealer.
Thank you for any help.
