T45 wrote:On my 2nd time around I went front sump. We hacked the xmember (a lot more than you did Steve) and massaged the bulge in the pan to fit. Anyways instead of making major pan mods we made major xmember mods and I was still able to run the Z swaybar by just lowering it and clocking the ps pump with a little clearancing on the block to get it higher. It is possible to keep the stock Z sway bar and it sits about 1/2" lower than the pan. It's pretty low but it's high enough for normal driving and speed bumps.
This crossmember is Nick's (npez) and I didn't hack the crossmember much because he already had a pan modified to work with a crossmember that was modified in this way.
The crossmember in my car is modified significantly more than this, and my pan is barely modified at all. The only modification to my pan was to clear the steering rack, there is no change to the sump portion of the pan.
I did exactly what you describe with the swaybar at first. I had the pump flipped upside down and the swaybar spaced down about an inch. Everything looked great up on jackstands and I was happy with the work.
Little did I know (or consider, lesson learned) that the swaybar rotated back and up as the suspension compresses. So even though there was sufficient clearance when in the air, while on the ground there was less than 1/8" at stock ride height, and the pan was showing damage from going over bumps. Also, the lever arm portion of the swaybar was getting dangerously close to the tension rods.
I had plans to heavily lower the car and I didn't want to run into binding issues. That is why I converted to a rear swaybar setup with a stock G50 Q45 bar. It was fairly simply to fabricate the brackets and the clearances are substantially better than stock. It also allowed my to properly mount the PS pump and gives me the option to put the AC in if I ever decided to.
Do yourself a favor and put the car on jackstands, remove both front shock/spring assemblies and swing the suspension through its full travel. Once you've confirmed clearances that way you should be confident you have no issues.
I'm not knocking your setup at all, I ran it for a while, I just don't want to see you run into problems down the road if there was something you missed.
