Looks great....those should be the rims that come with the EX35.rontek wrote:Even though they are 18" they are VERY different from stock. The tires are a ZR rated performance tire, not M&S, they are a little shorter on the sidewall and about 1" wider. Handling is MUCH improved. The reason I did not want to go larger is because you lose ride quality with lower profile, and because it appears the steering rack on the EX can be finicky, going far from the stock sizes could be asking for trouble. The pics are not the best, but I am pleased overall.
Could you give more details on what you've noticed regarding the handling being improved?rontek wrote:The tires are a ZR rated performance tire, not M&S, they are a little shorter on the sidewall and about 1" wider. Handling is MUCH improved.
Although....I would say that anything lower than a 40 profile on a tire and you sacrifice quality. There are lots of benefits with a lower profile tire.
From what I can tell, OE Wheels INCLUDE the caps in the price.EXceptional wrote:These are the nicest Rims I've seen so far on NICO for the EX35
So for the record on this thread, what is the Part Number of the Infiniti Rim Center Caps you bought... and how much are they ?
You left that off your List, up top.
Thanks , I am not a "Bling Bling" sort of guy !302@12psi wrote:I like those wheels a lot better then the "bling bling" that frequents this forum.
I would however liked to see a bit more rubber tucked under the EX.
Thank you for the compliment. I really had no idea what they would look like on the EX when I purchased them, but of everything I had seen, and especially for the price, I figured I would give it a shot. Once I had them on, they looked better than I had even expected.EXceptional wrote:These are the nicest Rims I've seen so far on NICO for the EX35
sounds about right... +38rontek wrote:I just found a piece of paper I had written some notes. I am pretty sure the offset is +38 . I will confirm Monday, but I am "almost" positive that is it.
Modified by rontek at 4:20 PM 6/5/2009
Thank You !CaribMon71 wrote:I really like those rims on this car. Great choice.
Thank You !BrokenTiller wrote:Very nice. I ended up with ugly 5 spoke rims from the dealer with my winter tires. Much prefer these.
