Skpike101 »
https://forums.nicoclub.com/skpike101-u90460.html
Tue Jun 03, 2008 5:13 pm
I noticed that there are a plethora of problems that are not exactly a one job fix. one thing breaks and causes another to "wear" (still good but doesn't work perfect) or stuff like that. i wish it was as easy as "oh i just need to change the battery!" lol ok enough with that
92 240 coupe w/93 engine. no idea how many miles had 3 different clusters.guessing about 200k - really high
so the no. 2 piston has some blowby but not to the extent of smoke.
one night i crank it up and it started smoking after about 5min. of idle. next day it cleared up, and never did it again. but since then it has had a power loss problem.
-loss of power like- (stock clutch)clutch depressed fully reving 2k 3 seconds to clutch out its at 1k
i still drive it every day, its just weak. but annoying
codes returned are 34 "knock sensor"
so i go to advance and buy one and replace it. still has the code. idk why. I checked the continuity between the ecm and connector like the fsm says. thats fine.
idk i'm kinda lost, and too busy to give a couple of days looking at it because it has to be driven.
if anyone needs pics of anything i can get them just say
