pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Mon Sep 04, 2006 7:41 pm
Ok I made a thread a while back about the differences in the truck block vs the 240 block and got the info I needed but now of course I have another question. I am getting the bottom end only from an early '90's hardbody so there arent any head issues as I will be reusing mine, but I would like to use floating wrist pins instead of the truck's standard press fit ones. If I were to buy a set of reconditioned 240 rods they should work with no problem right ? I am not sure exactly what brand of pistons I will use, but I will definately use high compression 240 style pistons that utilize floating wrist pins. Of course this still depends on if the truck engine I am getting is reusable, but if so then I will rebuild it and use it for a while as I rebuild my original engine to be capable of around 300-400hp. Since the amount of time that will pass between my install of the rebuilt N/A truck engine and the install of my beefed up and turbo'ed original engine is indefinite I am going to make the truck engine as powerful as possible to keep me happy.
