eliterit »
https://forums.nicoclub.com/eliterit-u12096.html
Sun Oct 01, 2006 12:18 pm
hello everybody
I have an issue with setting my timing on my ca18det.
I've read through some of the threads here about setting the belt and counting the teeth, and I get 39 cogs from cam to cam and 48 cogs from exhaust cam to crank mark on the crank gear. before i reinspected the belt, i was able to set the timing to 15degrees, however the car had absolutely no power below 3000rpm, even if i gave it wot, it would do nothing until after 3000 or 4000ish.
So after realizing the belt appears to be right on the money, i took the belt off anyway and reset it just to make sure i didnt mess up the first time. I put everything back together, and now i can only get the timing set to nothing greater than 10degress. i cannot move the cas anymore to set it to 15 degress. So i've turned the cas counter clockwise the most that it can go which is a setting of 10degrees.
Has anyone had this issue arise before? am i going to have to reset the belt now? I've also tried messing with the idle bolt but it seems to not function that effectively for some reason.
any help is greatly appreciated.thanks
