Another timing TDC question.....help..
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
While installing my chain and sprockets,and rotating by hand to check movement, the chain slipped and the top cam moved a about an inch, including the bottom cam, now will this be a problem??? I went ahead and relocated both cams back to original postion (notch poining up...) and finish installation. Is everything out of alignment because of these even if both cams are moved individually back to TDC position....
Will this be allright? Im going crazy with this..... Thanks
s13sr20chris
just set tdc at crankpoint cams upline up shiney links on chain
