agent4573 »
https://forums.nicoclub.com/agent4573-u215609.html
Mon Sep 23, 2013 7:25 am
So I got the motor running and it was working pretty awesome and felt pretty strong. Decided to check my timing just to make sure everything was set correctly and found it to be ~30 degrees BTDC. Adjusted it to 15 with a timing light hooked up to the #1 cylinder coil wire and now it stumbles off idle, doesn't pull nearly as strong and won't rev past 5500 rpm. Any suggestions besides dropping like 700 bucks for Nistune and re-programming anything?
Also, anyone happen to live north of LA with a wideband? I'm going to pull the plugs tonight and check them, but it would be nice to do a run or two with a wideband in the exhaust just to make sure I'm not super lean. The only adjustment I have is fuel pressure, but if I'm super lean, I'd be ok with running 60psi to richen it up a bit until I can afford the money for nistune.
Thanks.
