Another timing question....but different...
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Last time I had my timing chain replaced (some time ago..) on my nissan 240SX 1989. I noticed that the chain rattling was gone, but the car was slower and low in performance, lack of power. Well I checked the ignition position and check the timing on the car and is all good according to the Nissan manual. But by changing the timing on the car, it will feel back like it used to be in regards to power and speed....I think my mechanic failed to align the cams properly and just went with the alignment of the ignition at the end. I need to replaced the valve cover gasket (it leaks) this weekend, is there anything I can check while in there to ensure everything is align like is suppose to???
thanks
NISTECH
yea when you have the cover off hand crank your engine so the TDC mark on your crank pulley is on the mark. then look at your cam shafts and make sure they are on their appropriate marks. If they arent even close to the marks bring the engine around one rotation till you get to TDC again and then check to make sure the marks are right.
s13sr20chris
ign timing is good? if not it may be the oil pump shaft out of time.
bokinsmowls
Car: Should be obvious
arent our motors interference motors? If the cam timing is off, wont the piston hit the valve?
Q45tech
Most interference motors have a narrow window of accepability [1-2 teeth [some even 3 teeth] at cam, 1 at crank] before valve to pistion contact occurs.
At high rpm the rods [bolts] stretch and piston rises [plus expands with heat] so what seems ok manually may not be sufficient at high rpms.
bokinsmowls
the ka is an interference motor, right?
s13sr20chris
yup
