ill_sil »
https://forums.nicoclub.com/ill-sil-u20516.html
Sun Jul 16, 2006 7:30 am
Ok first ill list all my mods.-14 t28 @11lbs-MBC ball and spring-walboro fuel pump-FMIC-SAFC-2-wideband-SOHC MAF(new) running 6in 6out on the safc-SSAC manifold w/ turbo back 3" exhaust-timing is @ 15deg-running atmospheric BOV, Blitz -all injectors and plugs are working (i unplugged one at time)and ive got new plugs and there gapped at .30 BKR7E NGK'sNow the problemIm getting alot of lag in power.it feels as if ive got a huge turbo or something! The powerband starts at 4000rpms and up,and if i give too much throttle it hesitates.
its definately a timing issue because i fiddled with the cas and it got a little better, but still laggy,only high end power.
today i timed the car and went for a test drive, but it felt very slow and i felt as if i was hurting it so i stopped and went back to the shop. So then put it at TDC and pulled off the valve cover. everything was in order the cas was almost right on. I thought that maybe im off a tooth on the timing chain,but it was all correct cam position.
So my question is what else could i possiblly check? ignitor? cas?
PS: im pretty confident in the timing procedure i used, and i did notice that when i plugged the tps back in the timing was off a little (making it rediculously slow with backfiring etc.) ,so i just corrected it with it plugged in and it feels the same (drivable/laggy/highend power only)
